hello!
Someone has the data of the engine art. number :00-115-925? Must also hints of the same configuration
My system is KR16L6, KRC2, SOFTWARE V5.4.14, EXTERNAL AXIS MGU 0850-125.
motor data
- Robo_ter
in this Doc page 25 there is a engine art. number :00-115-925
Engine Mx_110_130_40_S0
Sorry just in German
Greeting Stefan
....das pdf wollt ich auch gerade anhängen
aber hier noch ein pampflet von Kuka mit einer Tabelle -vergleich alte neue Motoren, vielleicht auch mal hilfreich
in english
the external axis does not work, please check that the error in machine data
What's the failure message or did you get no message?
Pls. post a complet robot archive
test this:
$PMCHANNEL[7]=121
That's an other question, did you have a single break module on your 7. axis ??
You can see this module on top of the KSD-Module exists two green plugs with 8 and 4 pins
This is the arquive of the robot.
Please help me! -
Do you have a SingleBreakModule on the KSD-Module of the Axis ?
Then the Variable have to be $PMCHANNEL[7]=121
Without SingleBreakModule $PMCHANNEL[7]=21 is correct
Do you hear the Breaks of the Engine open ??
The robot has the following errors:
INCORRET SERVO PARAMETER A1.... TO A6
SERVO BUS DISTURBANCE DSE1
0 KPS MODULES AT DSE1<->PM CHANNEL[1]=20 INVALID VALUE.......TO PM CHANNEL[6]
POWER MODULE AXIS E1 NOT OR WRANGLY PLUGGED -
Hello , i think i have found your problem (axis 7 is a linear axis):
$machine.dat
1338 DECL EX_KIN $EX_KIN={[glow=red,2,300]ET1 #NONE[/glow],ET2 #NONE,ET3 #NONE,ET4 #NONE,ET5 #NONE,ET6 #NONE} ;EXTERNE KINEMATIKEN #NONE,#EASYS,#EBSYS,#ECSYS,#EDSYS,#EESYS,#EFSYS,#ERSYS
1339 DECL ET_AX $ET1_AX={[glow=red,2,300]TR_A1 #NONE[/glow],TR_A2 #NONE,TR_A3 #NONE} ;EXTERNE ACHSEN #NONE, #E1, #E2, #E3, #E4, #E5, #E6correct for linear axis:
15 $AXIS_TYPE[7]=[glow=red,2,300]1[/glow]
1338 DECL EX_KIN $EX_KIN={[glow=red,2,300]ET1 #ERSYS[/glow],ET2 #NONE,ET3 #NONE,ET4 #NONE,ET5 #NONE,ET6 #NONE} ;EXTERNE KINEMATIKEN #NONE,#EASYS,#EBSYS,#ECSYS,#EDSYS,#EESYS,#EFSYS,#ERSYS
1339 DECL ET_AX $ET1_AX={[glow=red,2,300]TR_A1 #ET1[/glow],TR_A2 #NONE,TR_A3 #NONE} ;EXTERNE ACHSEN #NONE, #E1, #E2, #E3, #E4, #E5, #E6correct for turning axis:
15 $AXIS_TYPE[7]=[glow=red,2,300]3[/glow]1338 DECL EX_KIN $EX_KIN={[glow=red,2,300]ET1 #EASYS[/glow],ET2 #NONE,ET3 #NONE,ET4 #NONE,ET5 #NONE,ET6 #NONE} ;EXTERNE KINEMATIKEN #NONE,#EASYS,#EBSYS,#ECSYS,#EDSYS,#EESYS,#EFSYS,#ERSYS
1339 DECL ET_AX $ET1_AX={[glow=red,2,300]TR_A1 #ET1[/glow],TR_A2 #NONE,TR_A3 #NONE} ;EXTERNE ACHSEN #NONE, #E1, #E2, #E3, #E4, #E5, #E6 -
Your KSD is mounted in the base cabinet, or did you have an extended cabinet with on top montage ????
Mounted in the gabinet base.
Is odd because the errors are for all AXIS!
Check all the Ethernet cables in your cabinet, check the wireing to the RDW box and check the wireing IN the RDW box
Hello,
Someone has the data of the engines for KRC1 (KR100-KR150-KR200 robots).
Best Regards -
Hi people!
We fineshed to install the external axis! But we have now an other problem!
1 - When we try to use the Automatic mode the robot says: (no. 221 ) MODE INADMISSIBLE E 2
2 - How to enable the T2 mode without install again? I remenber that we can change a ";" in a .dat file.
Thanks a lot!!
Look at Progress.ini in folder /init
Kundenversion=
;Customer version for internal control tasks
; 1 = KUKA (Basic type)
; 2 = VW (VKRC 1)
; 3 = KUKA (without mode T2)
; 4 = GM (General Motors !! not for R2.2.8 and lower !!)
; 5= KUKA (mit E2/E7 Schliessung)
KUNDEN_VERSION =1Is necessary to change anything? (remeber, I have a 7 axis into KRC2)
