help programieren
  • Hallo, ich frage, diese Frage auf Englisch, weil mein Deutsch schreiben ist nicht so gut ,
    hier ist sie:
    I have a kuka with crc1 controller
    i use it for Tig welding stainless steel constructions
    i have a question about how can i make programming parameters made simple.
    this is my problem, i use 2 variables for welding, weld current, en wire feed speed
    so when i write my program, and i start welding, this is a piece of my code:
    ….code ….
    z_wirespeed = 50 ; this is the speed of the external wire feeder)
    z_current = 120 ; this is the welding current
    o_shieldgas = true ; this is shield gas turned on
    o_startwelding = true ; this starts the welding
    … code …
    after welding i need to stop my welding source
    o_startwelding = false
    o_shieldgas = false
    etc
    the problem is when its an horizontal weld, the parameters differ from a vertical weld
    so i constant need to change these parameters (variables) and it becomes a great and long program
    I want it to look like this, in one line:
    WELD(50,120)
    and if it is possible one command to start welding, and put on the shield gas etc.
    how do i do this ?
    Bart. (Belgien)
  • this will be possible.
    for a subroutine make a separate src without a ini-fold.
    the def-line of the src may have two attributes:
    example:
    DEF  weld (current :IN,speed :IN )
    then declare the vars:
    int current
    int speed
    now you can go on....
    Wolfram (Cat) Henkel
  • a little advice:
    you can jump in the program with the trigger function.
    The advantage ist, that the robot will not stop when you switch the values.
    Example:
    trigger when distance = 0 DO weld(50,120) prio = -1 ; you have to set a priority for programms, -1 should mean "use what you want", else take something else / some are reserved!
    lin weldpos c_vel
    the outputs may have to be continued to make this work
    continue
    continue
    continue
    continue
