Hello all,
Today I’ve received a call from one of my customers telling me that with the new machine I’ve sold them he can’t delete code blocks like he is doing with older machines.
It seems that the operator is used to select programs and edit them in expert mode.
The old cell has the 5.2.15 version installed.
The new cell has the 5.6.8 version installed.
The user is doing those steps:
1. Select program.
2. Run and work with the program.
3. Stop the program.
4. Select a complete code block (shift + cursor).
5. Press delete.
6. Answer yes to the question “are you sure you want to delete…”
7. The cursor goes up to the beginning of the program.
8. Then the user goes to the specified line in order to see if the code block has been deleted or not.
8.a. And in the old robots the code block is gone. [expected behavior].
8.b. And in the new robot the code block is still there. [unexpected behavior].
Is it possible to get the old behavior implemented into the new cell?
As always thank you in advance!
