Die Website beschreibt die Einstellungen an einer echten Steuerung und nicht OfficeLite, dass auf einer virtuellen Umgebung läuft.
Hast Du diesen Post mal angeschaut:
Beitrag
RE: EthernetKRL und OfficeLite
your router has wrong configuration.
it duplicates existing connection between vxWorks and Win7e: 192.168.0.1 - 192.168.0.2).
i would recommend to first copy and run "Application" from inside OL.
this bypasses firwalls and router and should work right away with included EKI examples. this is very quick and easy to test and - if you cannot get this to work.... you have a bigger problem.
once above was confirmed to work, try to run "Application" from host OS (outside OL) and use router.
router need to…
router need to…
