INERRUPT
  • Ich schreibe als eine lineare Bewegung zu erkennen () zu unterbrechen, es wurde dann trat vakum nahm den Rohling mit Haufen und legte es in die Maschine und Bewegung UTB noch nicht zu Ende, bis das Werkstück
  • Hallo! Sprichst du zufällig Englisch?
    Greetings, Irrer Polterer!
  • I am an Armenian I communicate with you through an interpreter, which is why I would like to express my bad thoughts in advance izvenyayus, but what to do Using the Fn such, I want to vertical workpiece is taken from the stack and put into the machine I have one sensor and I want to use interrupt
  • My advice: Throw the interpreter into a garbage can. It's crap.
    Interrupt-example:
  • Softwareversion?
    And tell us the error message.
  • And the error message if the program reached "LIN_REL {Z -500}" ?
  • Sorry, but I'm not available at skype at the moment.
    I can't find any errormessage in your posts. If the Robot reaches the Line "LIN_REL {Z -500}" ther must be a errormessage. Please try to translate this message in english. The code "LIN_REL {Z- 500}" seems to be right. I can't understand why there is an error...
    One question, please: What is your proefession about KUKA-Programming.
  • I am a novice programmer I promote my knowledge in programming,
    I understand it is clear of the task and the way to solve the noise thank you very much for your help, I will add here programa I created 2 but your program's located in the folder AAAAA Thanks for you help
  • Ooops... :mrgreen:
  • with the help of a good friend IrrerPolterer today I finished my huge robot Thanks for the help, but of course there nyuansya I do not fully know all the knowledge but for me eshcho one step at deepening the knowledge hectickuka palletizing
    Einmal editiert, zuletzt von vto83 ()
