1. Dashboard
    1. Dashboard
    2. Suche
  2. Forum
    1. Unresolved Threads
  3. Members
    1. Recent Activities
    2. Users Online
    3. Team
    4. Search Members
  4. Jobs
  5. Articles
  6. Calendar
    1. Upcoming Events
    2. Map
  7. Shop
    1. Orders
    2. Shipping Costs
  • Login or register
  • Search
Roboterprogrammierer finden
This Thread
  • Everywhere
  • This Thread
  • This Forum
  • Articles
  • Pages
  • Forum
  • Blog Articles
  • Events
  • Files
  • Products
  • More Options
  2. Forum
  3. Industrieroboter Support
  4. KUKA Roboter
besuche unseren Hauptsponsor
Roboterschulung Online
Online Roboterschulung
Advertise in Robotics
Der Roboterkanal
Deutscher Robotikverband
Werben in Robotik
Werben für Robotik
CWRITE/CREAD in KukaSim
  • prokox1616
  • June 9, 2025 at 3:17 PM
  • Thread is Unresolved
  • prokox1616
    Points
    10
    Posts
    1
    • New
    • #1
    Hello,
    I try to learn using the CWRITE/CREAD commands for KUKA robots. I have a KUKASim 4.3 and I wonder if the information which i get in output window is strictly connected with the fact that I'm working on a simulator (controller is KR C4):
    KR 16 R1610 (integrated): Cwrite($FCT_CALL, STAT, MODE, "krl_fopen", "test.TXT", "w", HANDLE) is not supported.
    Below you can see my program (I took it from the manual about those instructions). So i think that the program tries to serach for a "test.txt" file in C:\KRC\ROBOTER\UserFiles
    and this must be a directory path from robot controller, so this can not work on simulator and i guess i need a real robot controller to test it. Am I Right?
    DEF  MAIN ( )
    DECL INT HANDLE
    DECL STATE_T STAT
    DECL MODUS_T MODE
    CHAR MYCHAR
    ;FOLD INI;%{PE}
      ;FOLD BASISTECH INI
        INTERRUPT ON 3
        BAS (#INITMOV,0 )
      ;ENDFOLD (BASISTECH INI)
      ;FOLD USER INI
        ;Make your modifications here
      ;ENDFOLD (USER INI)
    ;ENDFOLD (INI)
    MODE = #SYNC
    HANDLE = 0
    MYCHAR = "a"
    CWRITE($FCT_CALL, STAT, MODE, "krl_fopen", "test.TXT", "w", HANDLE)
    IF (STAT.RET1 == #CMD_ABORT) THEN
       IF (STAT.MSG_NO == -5) THEN
          ; error treatment if to many files are already open
       ELSE
    ELSE
    ; no error occured
    ; write a character to the file
    CWRITE($FCT_CALL, STAT, MODE, "krl_fputc", HANDLE, MYCHAR)
          ; error treatment
       ; close the file
       CWRITE($FCT_CALL, STAT, MODE, "krl_fclose", HANDLE)
          ; error treatment
    Display More
  • SCMI
    Reactions Received
    23
    Points
    698
    Posts
    106
    Occupation
    • June 10, 2025 at 1:11 PM
    • New
    • #2
    Hello,
    Where did you put this code? Is it in a submit?
    Is Kuka.Sim even able to run submits?
    My experience is that Kuka.Sim doesn't really work like a real controller, it's only to simulate movements of the robot. I think you would need OfficeLite to get it work properly.
Tags
  • 1
  • 33
  • 2
  • ABB
  • ABB Roboter
  • ABS
  • base
  • constant
  • CP_PARAMS
  • Dialog
  • EX
  • EXT
  • fanuc
  • Fehler
  • FRAMES
  • INIT
  • INITIALIZED
  • INITMOV
  • IRC5
  • joint
  • KRC2
  • KRC4
  • kuka
  • new
  • NONE
  • notify
  • PATH
  • PGNO_GET
  • profinet
  • PTP_DAT
  • PTP_PARAMS
  • P_ACTIVE
  • P_FREE
  • P_RESET
  • P_STOP
  • Quit
  • Roboter
  • RobotStudio
  • Schweißen
  • Sps
  • Sync
  • T1
  • t2
  • tcp
  • Tool
  • VALUE
  • VAR
  • vel_cp
  • vel_ptp
  • Yaskawa
AD
Einloggen für weniger Werbung
gesponserte Artikel
    August 11, 2019 at 7:02 PM
    August 21, 2019 at 8:17 AM
    June 2, 2021 at 11:29 AM
Job Offer
Werbung auf Roboterseite
Roboter programmieren lernen
Banner Robotik
Similar Threads
  • KUKA Sim 4.3 Achse 6 endlos
    • deselby
    • March 5, 2024 at 8:41 PM
    • KUKA Roboter
  • Praxisnaher Einsatz von KukaSim
    • M_a-r_k-u_s
    • June 5, 2023 at 2:50 PM
    • KUKA Simulationssoftware
  • Alternativen zu KUKA.Sim / Visual Components
    • Matu
    • July 4, 2023 at 2:18 PM
    • andere Simulationswerkzeuge
Tags
  • kuka
  • KUKASim
  • cwrite
  • Cread
  1. Privacy Policy
  2. Legal Notice
