The problem of the robot is not possible open a program by open button is only possible to select program and then is working. This problem is a little bit limitation of usage and programming robot. I don't know from where the problem came it just came first time and now is permanently on the robot. And also the file for example up132.dat with keep extension is created automatically in UP folder.
Only one solution which I find to solve the problem is to change program attributes for hidden .
Do You know maybe reason why is like this or maybe You know solution how to solve this. This is my first project on VKRc4 and I don’t have any support from customer side ( of course like always on small project ?)
I was try to change variable $edit_mod variable but it bring nothing
